ฝากพี่ผู้ใหญ่ด้วยนะครับ
และรุ่นใหม่ล่าสุดแรงๆๆๆๆๆๆๆCLASS HD
กำลังวัตต์ครับ
Model E3 3350
SPECIFICATION
STEREO MODE / Channels Driven
- 8 ohms............................................. 1350 W
- 4 ohms............................................. 2700 W
- 2 ohms............................................. 5000 W
BRIDGE MONO MODE
- 8 ohms............................................. 5000 W
- 4 ohms............................................. 8500 W
Peak output voltage per channel................180 V @8 ohm
Frequency response +0 / -3 dB...................20 Hz - 25 kHz
THD 20 Hz - 20 kHz for 1 W......................<0.1%
THD at 1 kHz and 1 dB below clipping..........<0.05%
Signal To Noise Ratio...............................>112 dBA
impedance
>15k ohm
Dimensions (WxHxD)..............................97x80x304 mm.
Model E3 2250
SPECIFICATION
STEREO MODE Channels Driven
- 8 ohms............................................. 1000 W
- 4 ohms............................................. 2000W
- 2.66 ohms......................................... 3350 W
BRIDGE MONO MODE
- 8 ohms............................................. 3600 W
- 4 ohms............................................. 6800 W
Peak output voltage per channel................130 V @8 ohm
impedance
>15k ohm
