ลืมบอกไปครับแอมป์รุ่นนี้ทางบริษัทผู้นำเข้าบอกว่าสามารถ ต่อใช้งานแบบโหลด 2 โอมห์ได้สบายครับ
แนะนำเพิ่มเติมครับ
Performance Data
Frequency Response: 0/-0.5dB ; 20Hz-20KHz, 0/-3dB: 5Hz-60KHz
Rated Output Power (Stereo): 210 watts at 8 ohms; 320 watts at 4 ohms; 420 wats at 2 ohms
• Rated Output Power (Mono): 650 watts at 8 ohms; 845 watts at 4 ohms
• At Full Power @4 ohms: 10.5A / 5.5A
• Signal to Noice Ratio: 20 Hz - 20k Hz - 100dB
• Distortion (SMPTE-IM): .05%
• Output Circuitry: AB
• Damping Factor (400 Hz): 200
Performance Data
Rated Output Power (Stereo): 400 watts at 8 ohms; 600 watts at 4 ohms; 900 wats at 2 ohms
• Rated Output Power (Mono): 1200 watts at 8 ohms; 1800 watts at 4 ohms
• At Full Power @4 ohms: 19.5A / 9.5A
• Signal to Noice Ratio: 20 Hz - 20k Hz - 102dB
• Distortion (SMPTE-IM): .01%
• Damping Factor (400 Hz): 280
Rated Output Power (Stereo): 600 watts at 8 ohms; 900 watts at 4 ohms; 1400 wats at 2 ohms
• Rated Output Power (Mono): 1800 watts at 8 ohms; 2800 watts at 4 ohms
• At Full Power @4 ohms: 32A / 16A
• Signal to Noice Ratio: 20 Hz - 20k Hz - 104dB
• Distortion (SMPTE-IM): .04%
• Output Circuitry: H
• Damping Factor (400 Hz): 350
