FIDEK Dual-Channel 31-Band Equalizer
Professional Dual Channel 31-Band Equalizer
1/3 octave filter
45mm long putt accurately adjust the equalizer range
Constant-Q filter
12dB/6dB enhancement and attenuation to adjust the optinal
Precision dual 12-segment LED output level meter
Dual-channel high-pass filter
Signal Noise Ratio:95dB
Maximum Line OOutput: �16dB
Dimension(HxWxD): 132X483X173mm
Weight: 5.0Kg
ใช่ตัวนี้หรือเปล่าหนอ
