แอมป์สุดคุ้ม น้ำหนักเบา กำลังขับสูงเสียงดี สภาพใหม่มากๆ อยู่แต่ในบ้านไม่เคยออกงานแต่อย่างใด
ขาย
7800ลดเหลือ
7300 รวมส่ง
WAVETECH DHP-240XF
Specifications
Sensitivity for full rated power..............1.4 Volts RMS or 0.775 Volts
Frequency Response 20 Hz to 20 KHz................... 1dB at any power level
Signal to Noise ratio 20 Hz to 20 KHz....................More than 103 dB
Total Harmonic Distortion (THD)0.1%....................Intermodulation Distortion (IMD)0.05%
Damping Factor..................................................800 From 20 Hz to 400 Hz.
Load Impedance................................................Safe with all types of loads
Output power stereo mode at 8 ohm (stereo).......520 + 520 Watts RMS (both channels driven)
Output power stereo mode at 4 ohm (stereo).......980 + 980 Watts RMS (both channels driven)
Output power stereo mode at 2.66 ohm (stereo)....1400 + 1400 Watts RMS (both channels driven)
Soft start - Against all severe voltage fluctuations
AC Input Voltage without affecting max. Output Power......180 V - 260 Volts AC. (when loading 4 ohms)
AC Input Voltage at moderate power operation................140 V - 260 Volts AC. (when loading 4 ohms)
Dimensions W x D x H ......................480 x 310 x 55 mm (1U1/2. 19" Rack mount )
Weight......................................................................................5.2 Kg.
