ยี่ห้อ : LAB.GRUPPEN
รุ่น : LAB.GRUPPEN FP7000
ราคาปกติ : 225,000.00 บาท
ราคาพิเศษ : 188,000.00 บาท
เว็บไซต์ :
http://labgruppen.com/products/fp_plus_series/c/fp_7000/รายละเอียดย่อ :
2 × 3500 W at 2 ohms
Power Amp, 2 x 1450W @ 8ohm, Speakon Outputs
รายละเอียดทั้งหมด :
LAB.GRUPPEN FP7000 2 × 3500 W at 2 ohms
The versatile FP 7000 supplies power output (2 × 3500 W at 2 ohms) well matched to a wide variety of applications. At the core of the FP 7000’s performance is a breakthrough advance in Lab.gruppen’s patented Class TD® output stage, an amplifier topology that approaches the exceptional efficiency of Class D while retaining the sonic purity of proven Class B designs. Further contributing to the remarkable efficiency of the FP 7000 is a Regulated Switch Mode Power Supply (R.SMPS™), which gives the added benefit of stabilizing rail voltages to the output even with wide fluctuations of mains voltage. A highly refined and updated circuit layout optimizes the interaction of R.SMPS and Class TD to produce the extraordinary power density of the FP 7000.
The FP 7000 is shipped with a NomadLink® network interface as standard. In conjunction with DeviceControl PC software, NomadLink allows monitoring of all key amplifier parameters and remote control of power on/off, channel mutes, and channel solo functions. (NomadLink requires the separate NLB 60E NomadLink Bridge & Network Controller)
