แนะนำตัว
ฝากงาน หางาน
กรุงเทพ และปริมณฑล
น้าบรรณ
ดาบเส อยุธยา
Import-Export BUTYL CARBITOL, Production of BUTYL CARBITOL
polychemicals12
13 ·
439
polychemicals12
พฤษภาคม 06, 2025, 12:55:20 am
Butyl carbitol sales, Butyl carbitol import, Butyl carbitol export
Butyl Carbitol 2025 by PKSN_05-05-2025
Production of BUTYL CARBITOL, Production of BUTYL CARBITOL,
Butyl Carbitol Distribution, Butyl Carbitol Import,
Butyl Carbitol Export Butyl Carbitol , Diethylene Glycol Monobutyl Ether,
BDGE, Diethylene Glycol Monobutyl Ether Butyl Carbitol Production ,
Butyl Carbitol Export Butyl Diglycol Production, Butyl Diglycol Distribution,
Butyl Diglycol Import, Butyl Diglycol Export Butyl Diglycol Production of Solvents,
Distribution of Solvents, Import Solvents , Export Solvents Production of BDEG,
Distribution of BDEG, Import BDEG, Export BDEG Solvent Production,
Distribution of Solvents, Import Solvents, Export Solvents
You can inquire about product information,
request for trial samples and order products at
Thai Poly Chemicals Company Limited (Solvent)
Tel No: 034854888
Mobile: 0893128888
Line ID: thaipoly8888
Email: thaipoly8888@gmail.com Web:
www.thaipolychemicals.com
PKSN BUTYL CARBITOL THAILAND
Butyl carbitol production, Butyl carbitol distribution,
Butyl carbitol import, Butyl carbitol export Butyl carbitol manufacturer,
BUTYL CARBITOL factory, Butyl carbitol solvent distribution factory,
Butyl carbitol solvent production, Butyl carbitol solvent in chemical group,
cheap price, Butyl carbitol company for mixing in detergent,
Butyl carbitol company solvent in chemical group,
wholesale BUTYL CARBITOL, Butyl carbitol solvent import-export,
BUTYL CARBITOL import, BUTYL CARBITOL export, BUTYL CARBITOL production,
Butyl carbitol solvent import, Butyl carbitol solvent export,
wholesale price, Butyl carbitol import-export, company selling chemical solvent,
Butyl carbitol solvent production, cheap price,
Butyl carbitol manufacturer For mixing in detergent,
Butyl carbitol chemicals Solvent in the chemical group Paint wholesale price,
Butyl carbitol solvent factory, Butyl carbitol
distributor Solvent in the chemical group Paint Accept butyl carbitol production ,
Import-export BUTYL CARBITOL, Butyl carbitol for mixing in detergent Factory price,
Butyl carbitol distributor Solvent in the chemical group Paint
Distributor Butyl carbitol Solvent in the chemical group Paint,
Wholesale Butyl carbitol solvent, Butyl carbitol solvent factory,
Butyl carbitol cheap chemical solvent Import butyl carbitol Water-soluble solvent,
Export butyl carbitol Water-soluble solvent, Export BUTYL CARBITOL,
Produce BUTYL CARBITOL, Wholesale Butyl carbitol Solvent in the chemical
Butyl carbitol solvent Wholesale price Produce butyl carbitol solvent Factory price,
Export solvent Butyl carbitol wholesale price, butyl carbitol production,
chemical solvent group, paint factory price, butyl carbitol solvent distribution cheap price,
butyl carbitol solvent factory, butyl carbitol solvent company,
butyl carbitol solvent company, butyl carbitol chemical solvent import,
butyl carbitol resin, chemical solvent group, paint factory price,
BUTYL CARBITOL wholesale production of butyl carbitol for mixing in detergent,
butyl carbitol solvent distribution, butyl carbitol solvent import,
butyl carbitol solvent export, butyl carbitol solvent factory
production of butyl carbitol chemical solvent, butyl carbitol solvent distribution,
butyl carbitol solvent import, butyl carbitol solvent export,
butyl carbitol solvent factory Solvents in the chemical group,
produce Butyl carbitol solvents, distribute Butyl carbitol solvents,
import Butyl carbitol for mixing in detergents, export Butyl carbitol solvents,
Butyl carbitol solvent factory produces Butyl carbitol. Solvents in the chemical group,
paint work, produce Butyl carbitol solvents, import Butyl carbitol solvents,
Export Butyl Carbitol Solvent, Butyl Carbitol Solvent Factory,
Produce Butyl Carbitol Solvent, Distribute Butyl Carbitol Solvent in Chemical Group,
Paint Work, Import Butyl Carbitol Solvent, Export Butyl Carbitol Solvent in Chemical Group,
Paint Work, Butyl Carbitol Solvent Factory, Produce BUTYL CARBITOL ,
Product Name: BUTYL CARBITOL
Chemical Name: Diethylene Glycol Monobutyl Ether
CAS Number: 112-34-5
Formula: C8H18O3
Preferred IUPAC name
2-(2-Butoxyethoxy)ethan-1-ol
Other names
Diethylene glycol butyl ether
2-(2-Butoxyethoxy)ethanol
DEG monobutyl ether
Butyldiglycol
Butyl carbitol
Butyl digol
BDGE
Butyl CARBITOL
is a type of glycol ether, colorless liquid with a sweet, ether-like odor. It also can be considered as slower-evaporating analog of ethylene glycol monobutyl ether. Coupling agent and solvent in household and industrial cleaners, rust removers, hard surface cleaners and disinfectants. Primary solvent in solvent-based silk screen printing inks. Coupling solvent for resins and dyes in water-based printing inks. Solvent for ball point and felt tip pen inks, and textile dyeing and printing. Coalescent for latex adhesives. Deactivator and stabilizer for agricultural pesticides. Diluent in hydraulic brake fluid applications, etc. Diethylene glycol butyl ether (DEGBE, 2-(2-butoxyethoxy)ethanol) is the organic compound with the formula C4H9OC2H4OC2H4OH. A colorless liquid, it is common industrial solvent. It is one of several glycol ether solvents. It has low odor and high boiling point. It is mainly used as a solvent for paints and varnishes in the chemical industry, household detergents, and textile processing.
ผลิตภัณฑ์ สารตัวทำละลาย, โซลเวนท์, Solvent
ที่บริษัท ไทยโพลีเคมิคอล จำกัด จำหน่าย ประกอบด้วย
OIL SOLVENT น้ำมัน และ สารตัวทำละลาย
Acetone อาซีโตน อะซีโตน
Acrylic Binder, Acrylic Emulsion อะคริลิค อีมัลชัน
Alcohol Ethoxylate, AEO, 3,5,7,9 mole แอลกอฮอล์อทอกซีเลต
Base Oil 150SN, 500SN, 150BS เบสออยล์ น้ำมันพื้นฐาน
Butyl Acetate, BA บิวทิลอาซีเตต บีเอ
Butyl Carbitol บิวทิลคาร์บิทอล
Butyl Cellosolve บิวทิลเซลโลโซล์ฟ
Butyl Diglycol, BDG บิวทิลไดไกลคอล บีดีจี
Castor Oil 36 Mole Ethoxylate คาสเตอร์ออยล์ น้ำมันละหุ่ง
Cellosolve Acetate, CA เซลโลโซล์ฟอาซีเตต ซีเอ
Cyclohexanone, CYC ไซโคลเฮกซาโนน ซีวายซี
Cyclohexyl Ketone ไซโคลเฮกซิลคีโตน
Diacetone Alcohol, DAA ไดอาซีโตนแอลกอฮอล์ ดีเอเอ
Dichloromethane, DCM ไดคลอโรมีเทน ดีซีเอ็ม
Dimethylformamide, DMF ไดเมทิลฟอร์มาไมด์ ดีเอ็มเอฟ
Dimethyl Ketone, DMK ไดเมทิลคีโตน ดีเอ็มเค
Dimethyl Sulfoxide, DMSO ไดเมทิลซัลฟอกไซด์ ดีเอ็มเอสโอ
Emulsifier อีมัลซิไฟเออร์
Ethyl Acetate, EA เอทิลอาซีเตต อีเอ
Ethylene Glycol Monobutyl Ether เอทิลีนไกลคอลโมโนบิวทิลอีเทอร์
Glycerine USP, Glycerol USP กลีเซอรีน กลีเซอรอล เกรดยูเอสพี
Glycol, Glycol Ether ไกลคอล ไกลคอลอีเทอร์
Hexylene Glycol, HGL เฮกซิลีนไกลคอล เอชจีแอล
Hydraulic Fluid, Hydraulic Oil น้ำมันไฮดรอลิก ไฮดรอลิกออยล์
Ketohexamethylene คีโตเฮกซะเมทิลีน
Lecithin (Soy Lecithin) เลซิติน เลซิทิน
Methylene Bichloride, MBC เมทิลีนไบคลอไรด์ เอ็มบีซี
Methylene Chloride, MC เมทิลีนคลอไรด์ เอ็มซี
Methylene Dichloride, MDC เมทิลีนไดคลอไรด์ เอ็มดีซี
Methyl Ethyl Ketone, MEK เมทิลเอทิลคีโตน เอ็มอีเค
Methyl Isobutyl Ketone, MIBK เมทิลไอโซบิวทิลคีโตน เอ็มไอบีเค
N-Methylpyrrolidone, NMP เอ็น-เมทิลไพร์โรลิโดน เอ็นเอ็มพี
Nonylphenol Ethoxylate NP4, 6, 9, 10, 15 โนนิลฟีนอลอีทอกซิเลต เอ็นพี
N-Propyl Acetate, NPAC เอ็น-โพรพิลอะซีเตต เอ็นพีเอซี
Paraffin Oil, Liquid paraffin พาราฟินออยล์ พาราฟินเหลว
Perchloroethylene, PCE เปอร์คลอโรเอทิลีน พีซีอี
Pimelic Ketone พิเมลิกคีโตน
Polybutene, PB 400, 950, 1300, 1400, 2400 โพลีบิวทีน พีบี
Polyoxyethylene Castor Oil โพลีออกซีเอทิลีน คาสเตอร์ออยล์
Polyquaternium-7, 10 โพลีควอเทอร์เนียม
Polysorbate 20, 60, 80 (Tween 20, 60, 80) โพลีซอร์เบต
Propylene Carbonate โพรพิลีนคาร์บดเนต พีซี
Propylene Glycol Mono Methyl Ether, PM โพรพิลีนไกลคอลโมโนเมทิลอีเทอร์ พีเอ็ม
Pure Acrylic อะคริลิคบริสุทธิ์
Rubber Oil, รับเบอร์ออยล์ น้ำมันยาง
Rubber Process Oil, Rubflex รับเบอร์โพรเซสออยล์
Silicone Fluid, Silicone Oil ซิลิโคนออยล์ ซิลิโคนฟลูอิด
Specialty Solvent, Please Contact TPCC สารตัวทำละลายชนิดพิเศษ
Surfactant, N70 เซอร์แฟคแตนท์ สารลดแรงตึงผิว
Tergitol 26L-3, 5, 7, 9 เทอร์จิตอล 26L
Tergitol NP4, NP6, NP9, NP10 เทอร์จิตอล เอ็นพี
Triacetin (PALMESTER) ไตรอาซีติน ปาล์มเอสเตอร์
Trichloroethylene, TCE ไตรคลอโรเอทิลีน ทีซีอี
Tetrachloroethylene เตตระคลอโรเอทิลีน
White Oil, White Mineral Oil ไวท์ออยล์ ไวท์มิเนอรัลออยล์
ACETATE อะซีเตต
Butyl Acetate, BA บิวทิลอะซีเตต บีเอ
Cellosolve Acetate, CA เซลโลโซล์ฟอะซีเตต ซีเอ
Ethyl Acetate, EA เอทิลอะซีเตต อีเอ
N-Propyl Acetate, NPAC โพรพิลอะซีเตต เอ็นพีเอซี
ALCOHOL แอลกอฮอล์
Benzyl Alcohol เบนซิลแอลกอฮอล์
Cetyl Alcohol, Hexadecanol-1 ซีติลแอลกอฮอล์
Cetyl Stearyl Alcohol, Fatty Alcohol ซีติลสเตียริลแอลกอฮอล์
Ethyl Alcohol, Ethanol เอทิลแอลกอฮอล์ เอทานอล
Isobutyl Alcohol, Iso-Butanol ไอโซบิวทิลแอลกอฮอล์ ไอโซบิวทานอล
Isopropyl Alcohol, Isopropanol, IPA ไอโซโพรพิลแอลกอฮอล์ ไอโซโพรพานอล ไอพีเอ
Methyl Alcohol, Methanol เมทิลแอลกอฮอล์ เมทานอล
n-Butyl Alcohol, n-Butanol บิวทิลแอลกอฮอล์ บิวทานอล บูทานอล
Stearyl Alcohol, Octadecanol-1 สเตียริลแอลกอฮอล์
ETHANOLAMINE เอทานอลเอมีน
Diethanolamine, DEA ไดเอทานอลเอมีน ดีอีเอ
Diethylene Triamine, DETA ไดเอทิลีนไตรเอมีน ดีอีทีเอ
Monoethanolamine, MEA โมโนเอทานอลเอมีน เอ็มอีเอ
Triethanolamine, TEA ไตรเอทานอลเอมีน ทีอีเอ
Triethylene Triamine, TETA ไตรเอทิลีนไตรเอมีน ทีอีทีเอ
Triisopropanolamine 85%, TIPA ไตรไอโซโพรพานอลเอมีน ทีไอพีเอ
ETHYLENE GLYCOL เอทิลีนไกลคอล
Diethylene Glycol, DEG ไดเอทิลีนไกลคอล ดีอีจี
Monoethylene Glycol, MEG โมโนเอทิลีนไกลคอล เอ็มอีจี
Polyether Glycol โพลีอีเทอร์ไกลคอล
Polyethylene Glycol, PEG โพลีเอทิลีนไกลคอล พีอีจี
Triethylene Glycol, TEG ไตรเอทิลีนไกลคอล ทีอีจี
PEG 200, 300 พีอีจี200 พีอีจี300
PEG 400, 600 พีอีจี400 พีอีจี600
PEG 1000, 4000 พีอีจี1000 พีอีจี4000
PEG 6000, 8000 พีอีจี6000 พีอีจี8000
ISOCYANATE ไอโซไซยาเนต
Diphenylmethane Diisocyanate ไดฟีนิลมีเทน ไดไอโซไซยาเนต
MDI, Methylene Diisocyanate เอ็มดีไอ เมทิลีนไดไอโซไซยาเนต
Polyester Resin, Unsaturated Polyester โพลีเอสเตอร์เรซิน
TDI, Toluene Diisocyanate ทีดีไอ โทลูอีนไดไอโซไซยาเนต
MONOMER โมโนเมอร์
Butyl Acrylate Monomer, BAM บิวทิลอะคริเลตโมโนเมอร์ บีเอเอ็ม
Methyl Methacrylate Monomer, MMA เมทิลเมทาไครเลต เอ็มเอ็มเอ
Styrene Monomer, SM สไตรีนโมโนเมอร์ เอสเอ็ม
Vinyl Acrylate Monomer, VAM ไวนิลอะคริเลตโมโนเมอร์ วีเอเอ็ม
PLASTICIZER พลาสติไซเซอร์
Chlorinated Paraffin, CPW คลอริเนตเนตพาราฟิน พลาสออยล์
Dibutyl Phthalate, DBP ไดบิวทิลพทาเลต ดีบีพี
Di-2-ethylhexyl-Adipate, DEHA ไดเอทิลเฮกซิลอะดิเปต ดีอีเอชเอ
Di-2-ethylhexyl-Phthalate, DEHP ไดเอทิลเฮกซิลพทาเลต ดีอีเอชพี
Di-isononyl Phthalate, DINP ไดไอโซโนนิลพทาเลต ดีไอเอ็นพี
Dioctyl Adipate, DOA ไดออกทิลอะดิเปต ดีโอเอ
Dioctyl Phthalate, DOP ไดออกทิลพทาเลต ดีโอพี
Dioctyl Terephthalate, DOTP ไดออกทิลเทเรพทาเลต ดีโอทีพี
Epoxidized Soybean Oil, EPO อีพอกซิไดซ์ซอยบีนออยล์ อีพีโอ
Epoxidized Soya Bean Oil, ESBO อีพอกซิไดซ์ซอยยาบีนออยล์ อีเอสบีโอ
Non-Phthalate Plasticizer พลาสติไซเซอร์ ปลอดสารพทาเลต
Phthalate Free Plasticizer พลาสติไซเซอร์ พทาเลตฟรี
Trioctyl Trimellitate, TOTM ไตรออกทิลไตรเมลลิเทต ทีโอทีเอ็ม
PROPYLENE GLYCOL โพรพิลีนไกลคอล พีจี
Dipropylene Glycol, DPG ไดโพรพิลีนไกลคอล ดีพีจี
Monopropylene Glycol, MPG โมโนโพรพิลีนไกลคอล เอ็มพีจี
Polypropylene Glycol, PPG โพลีโพรพิลีนไกลคอล พีพีจี
Propylene Glycol EP, MPG-EP โพรพิลีนไกลคอล เกรดอีพี พีจีเกรดอีพี
Propylene Glycol USP, MPG-USP โพรพิลีนไกลคอล เกรดยูเอสพี พีจีเกรดยูเอสพี
SPECIALTY SOLVENT สารตัวทำละลาย ชนิดพิเศษอื่น ๆ
Please Directly Contact
Technical Sales (Oil & Solvent Division)
BY PKSN CARBITOL TPCC 2025
Keywords : Distribute BUTYL CARBITOL, Import BUTYL CARBITOL,
Export Butyl Carbitol for Mixing in Detergent,
BUTYL CARBITOL Factory, Produce Butyl Carbitol Chemical solvents,
Distributor of Butyl Carbitol Solvents, Import Butyl Carbitol Solvents,
Export Butyl Carbitol Solvents, Butyl Carbitol Solvent Factory,
Produce Butyl Carbitol Solvents , Produce BUTYL CARBITOL at Factory Price,
Export BUTYL CARBITOL at Wholesale Price, Produce BUTYL CARBITOL
Distribute Butyl Carbitol Solvents in Chemical Group, Paint Work at Cheap Price,
BUTYL CARBITOL Factory, Butyl Carbitol Company for Mixing in Detergent,
Import Butyl Carbitol Solvents, Export Butyl Carbitol Solvents,
Produce Butyl Carbitol Chemical Solvents, Distribute Butyl Carbitol Solvents ,
Butyl Carbitol Solvent Factory, Butyl Carbitol Solvent Company,
Import Butyl Carbitol Solvents in Chemical Group, Paint Work,
Export Butyl Carbitol Solvents, Produce Solvents Butyl carbitol factory price,
butyl carbitol solvent export wholesale price,
บิวทิลคาร์บิทอล, BUTYL CARBITOL, ผลิตบิวทิลคาร์บิทอล,
นำเข้าบิวทิลคาร์บิทอล, ส่งออกบิวทิลคาร์บิทอล
polychemicals12
Re: Import-Export BUTYL CARBITOL, Production of BUTYL CARBITOL
พฤษภาคม 11, 2025, 08:43:50 pm
ดันกระทู้
polychemicals12
พฤษภาคม 23, 2025, 11:19:13 pm
ดันกระทู้
polychemicals12
พฤษภาคม 28, 2025, 10:20:34 pm
ดันกระทู้
polychemicals12
พฤษภาคม 29, 2025, 10:37:50 pm
ดันกระทู้
polychemicals12
พฤษภาคม 31, 2025, 09:10:10 pm
ดันกระทู้
polychemicals12
มิถุนายน 01, 2025, 08:23:32 pm
ดันกระทู้
polychemicals12
ตอบกลับ #7 เมื่อ:
มิถุนายน 07, 2025, 09:57:55 pm
ดันกระทู้
polychemicals12
ตอบกลับ #8 เมื่อ:
มิถุนายน 08, 2025, 09:18:31 pm
ดันกระทู้
polychemicals12
ตอบกลับ #9 เมื่อ:
มิถุนายน 09, 2025, 10:22:30 pm
ดันกระทู้
polychemicals12
ตอบกลับ #10 เมื่อ:
มิถุนายน 11, 2025, 09:03:06 pm
ดันกระทู้
polychemicals12
ตอบกลับ #11 เมื่อ:
มิถุนายน 12, 2025, 09:50:11 pm
ดันกระทู้
polychemicals12
ตอบกลับ #12 เมื่อ:
มิถุนายน 16, 2025, 08:53:10 pm
ดันกระทู้
แนะนำตัว
ฝากงาน หางาน
กรุงเทพ และปริมณฑล
น้าบรรณ
ดาบเส อยุธยา
