รวมงานบางส่วนของ ป้าเอิ้น วาเลนไทน์88 ค่ะ
ออฟไลน์ EarN Valentine88
    • กระทู้: 1739
  • "ยังมีเรื่องราวอีกมากมายที่เราไม่รู้"
    • http://www.bluecase.co.th/
ฤดูกาลใหม่ บลูเคส ไลท์&ซาวด์  บริษัทลูกของ  วาเลนไทน์88  สั่งตัวนี้มาใช้งานค่ะ
All neodymium components, “light” weigh but “heavy” sound pressure.
Special “Equal Path Length” waveguide horn, optimized sound delivery.
*Durable square-stamped steel grill, smooth and natural desperation
*Cozy human-oriented handle, easy carry or lift
*Typical trapezoidal cabinet design, seamless connection between speakers.
*Flexible rigging design, either vertical line array suspension or ground stack, or even horizontal stacking as a matrix
*Customized multi-ply birch plywood with strictly control for Resin Sold Content and glue Spread.
*Built in Class II dual high frequency protect circuitry ensures stable performance.
*Strong directivity capacity, precise sound dispersion
OMEGA matrix line array system easily sanctifies all requirements for less then 100,000 audiences live venue. Perfect three-way construction with dual 12” LF woofers, can meet all demands for different gigs. No matter horizontal or vertical rigging, seamless connection between each unit is always extremely user-friendly.
Well-designed rigging system fully satisfies any needs of suspension for touring, rental or permanent installation.
Specifications:
Model
OMEGA
Frequency response
40Hz-18KHz
Components
Hi:2x3"compression driver neodymium; Mid:1x10"neodymium(75mm voice coil ); Low: 2x12"neodymium(100mm voice coil)
Directivity angle
H100°V7°
Sensitivity
Hi :113dB; Mid :105dB; Low :100dB
Impedance
Hi:16 ohm; Mid:16ohm; Low:2*8 ohm
Long-term power(RMS)
Hi:160W; Mid:350W; Low:1000W
Peak power
Hi:320W; Mid 700W; Low:2000W
Maximum SPL
Hi:134dB(peak:141dB); Mid:130dB(peak:136dB); Low:130dB(peak:136dB);
Connection
2x 8-pin Neutrik Speakon
Product dimensions(W*D*H)
1258x550x386mm
http://www.facebook.com/valentine.lightandsound?ref=tn_tnmn<br />http://www.bluecase.co.th/<br />http://www.valentine88.co.th/<br />http://www.factoryfm.in.th/<br />59/16-17 หมู่2 ตำบลไทรน้อย อำเภอไทรน้อย นนทบุรี 11150 <br />โทร 0-2225-5524,08-1558-8432,08-1807-8439 แฟกซ์ 0-2225-6225<br />เลขบัญชี ธ
    • กระทู้: 1739
ข้อดีของตัวนี้คือใช้ได้ทั้งตั้งและแขวน  น้ำหนักเบาแต่ได้เสียงที่ดังและหนักแน่นมากอีกด้วยค่ะ  เร็วๆนี้คงได้ลองกันค่ะ
    • กระทู้: 1739
เข้าสตูกันยาวๆทำเทปสต๊อคกันยาวๆไปค่ะ
    • กระทู้: 1739
ผู้หญิงเริ่มเข้ามาทำงานแบบนี้ในวงการกันมากขึ้นค่ะ
ออฟไลน์ น้าบรรณ
  • เสียงดนตรี คือเสียงสวรรค์
    • กระทู้: 1631
  • MUSIC IS MY LIFE
ลำโพงป้าเอิ้นสวยกว่า น้อง อั้ม .........
สุบรรณ หงษ์เวียงจันทร์  473/28  ลาดปลาเค้า 63  แขวงอนุสาวรีย์   บางเขน  กทม. 10220
https://www.facebook.com/ban.jasmine
Line       : 097 029 2666
    • กระทู้: 1739
Specifications:
Model
OMEGA
Frequency response
40Hz-18KHz
Components
Directivity angle
H100&deg;V7&deg;
Sensitivity
Impedance
Peak power
Maximum SPL
Connection
1258x550x386mm
ทั้งสวยทั้งดีจริงๆค่ะน้าบรรณอิอิอิ
    • กระทู้: 1739
แร็คกันกระแทกมาตรฐานโหลดขึ้นเครื่องก็ผ่านฉลุยค่ะ  สมควรนำมาใช้ในบ้านเรากันรึยังค่ะ
    • กระทู้: 1739
ศึกวันแดงเดือดค่ะอิอิอิ
    • กระทู้: 1739
มาปลูกต้นไม้เพื่อแม่กันค่ะ
    • กระทู้: 1739
ไปดู อั้ม  พัชราภา  ตำส้มตำกันดีกว่าแก้เซ็งค่ะ
http://www.youtube.com/watch?v=kaE22fwJigg&feature=player_embedded
    • กระทู้: 1739
สักครกไหมค่ะ
ออฟไลน์ เต๋อ อุตรดิตถ์
  • - สายตรวจมหากาฬ -
  • ทิกเกอร์ทีม
    • กระทู้: 2009
  • ทีมงานรักสงบ E22 ZYQ
สักครกไหมค่ะ
ไทย ปู ปลาร้า ไม่เผ็ด 1จานครับป้า...........
นายวิวัฒน์ โพธิ์เจริญ โทร.084-592-4909
 264 หมู่2 ต.บ้านด่านนาขาม อ.เมือง จ.อุตรดิตถ์ 53000
    • กระทู้: 1739
สักครกไหมค่ะ
จัดส่งทางไปรษณีย์ไทยรอรับด้วยค่ะพี่อิอิอิ
    • กระทู้: 1739
ท่านใดจะสั่งเพิ่มเติมลงชื่อสั่งใว้ได้เลยค่ะ  เดี๋ยวร้านปิดนะคะอิอิอิ
    • กระทู้: 1739
เนื่องจากภาพมีคำถามเข้ามาอีกว่าระบบเสียงจะใช้ประมาณไหน  แต่ก็เคยลงไปแล้วแต่ก็จำไม่ได้ว่าอยู่ตรงไหนค่ะ
